Second build and an opps call for help!
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=18417
Author:  zac_in_ak [ Sun Aug 17, 2008 2:02 am ]
Post subject:  Second build and an opps call for help!
well I am on my second kit build. This one I have to do quite a bit more then the first. It is a clone of the stew mac kit.
24 clamps is NOT enough good thing I got them at the borg for 37 cents
I have been going ok but tonight I had a boo boo I am not sure how to fix.
I put in the rosette and then came back later to plane it down and promptly tore off a chunk. I decided to pull out the rest and now I have no rosette. I could try my hand at making a wood one but don't think I can do a good enough job or maybe some colored epoxy.. any suggestions? oops_sign
Author:  bluescreek [ Sun Aug 17, 2008 7:14 am ]
Post subject:  Re: Second build and an opps call for help!
Rosettes are not hard. I learned not to do anything to the rosette until it is installed. Not to help you out ,what kind of rostette do you like? Wood is cool. I say try and make one , if that doesn't work out call for help. I can make a rosette as can alot of people here. We are here to help
john hall
blues creek guitars.
Also check out GRIZZLY.com they have material as does stewart macdonald
Author:  Jeremy Douglas [ Sun Aug 17, 2008 9:29 am ]
See if you can order another rosette wherever you got the kit from.
Author:  pnj [ Sun Aug 17, 2008 2:33 pm ]
I just build that same kit. When i did the rosette, I used super glue and then a sanding block until I got the rosette down closer to the wood. Then I scraped with a razor until I was much closer. Then sanded the entire top piece.
I think my approach stresses the rosette less, so there's less chance of it coming out. or maybe it was the super glue...:)
I'd try some colored epoxie for a fix. Might be hard to sand flush though and it might leak out and stain the rest of the wood around the hole.....
I guess I'm not much help...
Author:  zac_in_ak [ Sun Aug 17, 2008 4:04 pm ]
Someone suggested trying to make one in a patchwork pattern out of scrap and then I remembered some nice wood rosettes Ive seen in wood here so I think I may try to do one in wood or buy some veneer strips and trim them to size I will post pics of my fix when done.
